주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Can water get trapped under the screen resulting in an odd white stain
I was cleaning my iPhone 5, I used an old toothbrush to get gunk out of the small crevices. I also used electronic wipes near the silent mode switch. I powered the device back on, and when it was booting up I saw a large white stain on the corner of the device. It slowly disappeared after a few days, but it’s still somewhat there. Is this water? Is it permanent? How can I fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
im pretty sure if its caught between the glass in the LCD you might be out of luck. can u take a picture of it?
i would go into this expecting to have to replace the screen but one thing that i would try is trying to get some alcohol in there. use the highest percentage you can find though. 90+% id say 99 if you can get your hands on it. let it soak through and then air it out for a couple of hours ATLEAST and then try to power it up and see how it looks before completely reassemble.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Can I use hydrogen peroxide?
i wouldnt. that stuff would probably cause alot of bubbles and what not to be trapped. alcohol is your best bet as itll evaporate on its own.
댓글 달기
귀하의 답변을 추가하세요
Rob 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 64
