주요 콘텐츠로 건너뛰기
2016 Retina MacBook의 업데이트 버전. 모델 A1534, EMC 3099. 더 빠른 Kaby Lake 프로세서 최대 1.4 GHz Core i7과 Turbo Boost 최대 3.6 GHz, 50% 더 빨라진 SSD, 그리고 최대 2배 메모리 지원을 제공합니다.
82 질문 전체 보기
I used my computer last night, now it won’t turn on or charge up.
I just used my macbook last night to do homework then watch youtube. I left it plugged up when I went to bed. This evening it won’t turn on or charge up. I’m not sure what is wrong with it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Here are some things you can try: 1) With the charger plugged in, press and hold the power button for about 10 seconds. Then press the power button again. If the machine still does not power on, move onto the next step 2) Attempt to reset the SMC. After resetting the SMC, attempt to power on. If you still aren’t able to power on, move onto the next step 3) Try using a separate known-good charger. If you don’t have access to a charger you can take it to a tech shop and ask them if they can try to charge it as a free service. If it charges using a separate charger there may be an issue with your charger and it might need to be replaced. If none of these steps work for you there may be a hardware issue with your machine. If that’s the case I would recommend having it diagnosed by a Mac repair shop. If you’re feeling adventurous you can try disconnecting and reconnecting the battery, but be forewarned that these models can be a little tricky to open safely. Here’s a guide for accessing the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lexie Savannah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 41
