주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
업계 최고의 노이즈 캔슬링 기술과 편안한 착용감으로 찬사를 받은 Bose 최초의 무선 노이즈 캔슬링 헤드폰입니다. 2016년 6월에 출시되었습니다.
One of the earpads can rotate a full 360 degrees where it used to stop
As stated in the title, one of the earpads on my Bose QC 35 II headphones can rotate a full 360 degrees of motion. It does not make any clicking sound in doing so and rotates smoothly without any extra force applied. The other one has limited rotational ability. Is there some way that I can fix this myself?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
only real way since i cant find any kind of schematics for this thing is to tear it down your self. carefully and look to see if there are any pins or things that are on the right side that the left side or vice versa has.
is so youll have come come up with a way to replace it. (manufacture a new pin or something)
best bet is to check ebay and see if theres a person that either has a dead unit for CHEAP or someone that sells the headband plastic arch piece
https://www.ebay.com/itm/333633776879?ch...
the only other alternative is to send it to bose so they can replace the entire headband.
good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Definitely sounds like a solid procedure. Thank you!
의 공유
댓글 달기
답변을 추가하세요
Jacob Andersen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 34
전체 시간: 1,521
