주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Trick to unlock Forget Password for iPhone 4 on iOS 6.1.6
To avoid being a lock for many years or hours, what is the trick to unlock my old iPhone 4. I did remember my Apple ID and username and password.
However, I forget my iPhone password.
Is it better to try 4 times each day to avoid being lockout for a longer time?
Or range for week or month, does anyone have to try this trick?
Now the iPhone is disabled
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
are you trying to get into the phone for info that you need off of it or is it just to use it and you dont care about the data?
i need the data
댓글 달기
답변 1개
if youve forgotten the passcode then it looks like youre kind of out of luck. i would recommend taking it slow like you were doing and attempting to unlock a couple times a day for it to reset.
https://support.apple.com/en-us/HT204306
hopefully you have this phone backed up some where, if not then youre kinda SOL if it gets locked out completely.
good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
David Liong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 83
