주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Won't turn on after repair
We replaced the top cover unibody due to a faulty keyboard and to replace the battery. We used the ifixit video for this repair. Dismanting was fairly straight forward with the exception of disconnection of some of the connections being harder to remove than appeared in the video. After replacing the unibody we reconnected all the parts (which are many) and installed the new battery. We then attached the back cover and tried to fire it up. nothing……….. we decided we may need to charge the battery - so we did and got the Apple Chime as soon as we connected the power cord - we got no reaction from the new keyboard. We let it charge for an extended period - tried it - nothing. My gut reaction is that we damaged the Logic Board in the process so I’ve ordered one. Does anyone have any thoughts.
Thanks,
Danny J
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Are you sure you properly fitted the ribbon cables into the connectors? There is a latch that needs to be folded down.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
djenkins 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 13
