주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
Power button randomly presses itself
Hi guys,
Got a randomly rebooting iPhone 3G here that worked fine docked for some reason.
Replaced the battery using the guide found on this site.
Back together the phone worked fine but it kept locking itself and showing the power off slide bar. I have a feeling that the power button presses itself randomly or something.
What can I do to fix this except cleaning the buttons and hoping that that works? Going to try that later today.
Update
Ive cleaned the power button and the power button contacts. The button stil doesnt work. Im trying to take the phone apart again to see if it solves the problem.
Volume buttons work fine as does the vibration switch. Could it still be the flex that is broken or is it more likely the actual button isnt making contact with the flex.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I have removed cable 5 from the logic board. The problem is gone so next step is to try and take apart the button and clean it or install a new flex.
댓글 달기
답변 2개
가장 유용한 답변
You first need to find out wether it is actually the button itself that is causing the issue or something else. Try this:
Remove the connector #5 which is connecting the power button to the mainboard with a powered phone. Check if the problem still persists:
- Problem is gone → There is a problem with the physical power button. Replace this flex to solve the problem or you might try to disassemble the power button and clean between the metal of the button and the gold traces on the flex.
- Problem still persists → Problem with your logic board. Had this one time before. Ultrasonic cleaned the Logic board solved the problem that time.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
+ good clear explanation.
댓글 달기
sometimes the center middle dimple gets pushed out of center. remove and use clear light scotch tape and re install metal dimple back to the center position. worked for me. good luck
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Stefan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 3,475
