주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Problems after replacing SSD
I need some guidance in replacing my SSD in my 15” MacBook Pro.
I purchased the OWC Aura SSD and thought I was following the instructions they provided with it, but I think they should have provided more instructions than what they did.
I put in the new SSD, and put the case back on turned on the computer and pressed the cmd+option+r and the first thing that popped up on the screen was a question mark and it never moved from that point.
So, what did I wrong or is there another procedure I should have followed or did I miss a step because now I reading about cloning and what not?
I’m lost. Can someone help?
Will
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
What was the macOS release your system was running before you took out the Apple SSD? This is important to know before we can go forward.
댓글 달기
답변 1개
가장 유용한 답변
Try booting again, but this time only press/hold Command and R. You should boot into internet recovery, try installing macOS on the new OWC drive, if the computer can’t “see” the drive, you’ll have to put the original drive back in and update to (at least) macOS High Sierra.
I believe it has to do with the new APFS, (Apple File System) that was implemented in HS and the computers firmware. In fact, OWC should have included paper work on it, I remember mine did.
Your getting the question mark folder because the computer can’t find a bootable source; which makes sense because the new OWC drive will be blank. (No OS)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
W JENKS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 31
