주요 콘텐츠로 건너뛰기
Released in 2006, the 19" Dell Ultrasharp 1907FPc is a solid budget LCD monitor with four USB 2.0 ports, as well as VGA and DVI inputs.
3 질문 전체 보기
The monitor has display problems
A friend of mine’s computer monitor tends to flicker rapidly and display lines on the top of the screen with the section above this being normal, but the area below significantly higher in brightness. The flickering tends to go away after a few minutes. Can you tell me what the problem with the monitor is? I’m guessing an issue with the graphics card, but it could be something else. Thank you!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hey Michael,
Without more detail, kind of hard to say, but I think you are on the right track. If it isn’t a physical connection or the screen itself, it is probably a driver issue.
Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Michael Deitz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 77
