주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
4S Battery Life
Can one get a longer life battery?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
This is a problem Apple is working on. At this time they are trying to determine if the problem is in the hardware or the software. Be patient--some solution should be out soon.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
rj713 is correct, but if you want to save some battery life while Apple tries to figure this out, here are a few battery saving tips:
- Go to Settings>Location services. Then turn off anything that you don't want to constantly know your location.
- Go to Settings>Mail. Then turn off "Fetch New Data." This will make it so that you have to tap on the Mail icon to check your mail, but will save your battery life considerably.
- Go to Settings>Brightness. Then turn it down as far as you can deal with. Turn auto-brightness on.
- When you aren't using WiFi, go to Settings>Wi-Fi. Then turn it to "off."
Each of these will give you some extra battery life. I did them to my phone and have noticed considerably longer life, especially from the first two tips.
Hope this helps!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Miguel Moreno 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 975
