주요 콘텐츠로 건너뛰기
A2115/2020 / 프로세서 3.1GHz 6코어 i5부터 최대 3.8GHz 8코어 i7까지. 2020년 8월 4일 출시.
44 질문 전체 보기
Will it boot with only one 8G stick of ram?
Will this iMac boot with only one stick, or does it REQUIRE a pair? Also, does it/they have to be installed in any particular slot? This iMac won't turn on at all. I got it with NO ram at all because the previous owner used it all in his new iMac.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If we review this Apple T/N Install memory in an iMac
We’ll find this statement “If you have mixed capacity DIMMs, see the install memory section for installation recommendations.” And we jump down to that section: “iMac (Retina 5K, 27-inch, 2020) DIMMs have a notch on the bottom, slightly left of the middle. If your DIMMs are mixed in capacity, minimize the capacity difference between Channel A (slots 1 and 2) and Channel B (slots 3 and 4) when possible.
So you really can’t mix within the channel only across channels. So you’ll need to install your different RAM sizes in Slot 1 and Slot 3. Don’t forget to allow the system to initialize which can take awhile!
Given the cost and the performance benefit I would just go with a matched pair within each channel pair.
해당 답변은 도움이 되었습니까?
점수 1
댓글 7개:
Hi Dan. Thanks for the response. I will edit my question to be more specific.
This iMac won't turn on at all. No fan, no display, nothing. I got it with NO ram at all because the previous owner used it all in his new iMac. Can this particular iMac boot with only one stick, or does it REQUIRE a pair?
@rippegari - What is the size of the SO-DIMM's you are trying to use?
@rippegari - Well... you didn't really answer the question.
So being a single SO-DIMM I'm guessing its the 8 GB unit. Put it into Slot 1, turn your system on and go get a cup of coffee and some breakfast. When you get back your system should be booted up (it does take a good amount of time for it to initialize)
But if the RAM was pulled is the drive still present or just wiped? You maybe greeted with a blinking question mark in a folder.
Frankly, I always install two SO-DIMM's.
Apologies! Yes, it is one 8GB unit. I'll give it another go. Thanks,
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
James 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 7
전체 시간: 485
