주요 콘텐츠로 건너뛰기
Repair guides and support for the first generation Chevy S-10 (4WD model T-10) Blazer, a mid-size SUV based on the S-10 pickup truck. Closely related to the GMC Jimmy.
How do I change my fuel filter?
Having trouble and need instructions on replacing my fuel filter for my 94 chevy s10 blazer with a vortex motor
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Relieve fuel pressure. Everything I've found says make sure vehicle is off and key out, and loosen gas cap.. Fuel filter will be located on the driver's side frame rail. Theres a strap holding it, with a bolt on top and on bottom. Take those out and set aside. You'll need two wrenches for the next part. One for the fuel line connector and one for where the connector screws into. The fuel line side is the one that spins, you're just holding the filter. Undo each side, I'd recommend having some rags handy for the fuel. Take it off. Put new one in by doing everything above in reverse. Make sure you put it in correctly. Input (in) should be facing the rear of the vehicle. Out should be towards engine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Christa Lovegrove 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 25
전체 시간: 552
