주요 콘텐츠로 건너뛰기
닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
704 질문 전체 보기
Diagnosing short inside Nintendo Switch
My Nintendo Switch suddenly wouldn't turn on or charge. Nothing on the screen, no reboot/reset trick I have tried worked.
I often used a normal USB-C instead of the official charger, which might have damaged it.
I tested the current while charging (/w official charger) and got 0.02A without the battery and 0.08A with the battery.
Note: The battery and charger was "known working" and I tested with multiple battery's and chargers.
I also tested the coil and fuse which worked fine.
I tested all capacitors in continuity mode and one had shorted out (Blue).
Some were showing no reaction, on either side, to ground (Red)
Something noteworthy about the capacitors is how all the larger ones, and almost only the larger ones, on the board, were the ones acting weird.
Could replacing any of the chips or capacitors fix the capacitor short?
Could anyone please help me find the schematics and boardview of the pre-2020 Nintendo Switch?
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
check around blue circled for shorts
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
arvid werlin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 53
전체 시간: 1,549
