주요 콘텐츠로 건너뛰기
2018년 7월 출시, 15" MacBook Pro, 모델 A1989, True Tone 기술 15.4 inch LED-백라이트 화면, TouchID, 및 최대 Core i9 프로세서 여섯 개.
205 질문 전체 보기
Broken display cable on MacBook Pro 15 2018 (A1990)
I managed to accidentally rip one of the cables that go inside the display.
Is it beyond repair? Because I know that you can disassemble the display, but I am not sure that would actually help. Or getting a new assembled display is the only option?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Not good ;-{
Time for a new display there is no means to repair or replace this cable.
This ribbon cable connects directly to the glass LCD display similar to how the iMac T-CON is attached as you can see here
Unlike the iMac you only have two ribbon cables (green) to the LCD panel which are fused to it and replacing the LCD is not really possible as its a custom panel to Apple.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi
I have the same problem. In my opinion, this is a wrong construction. Apple refuses out of warranty repair. The same was true for 13 inch computers (flexgate). They should do service actions.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Well ... Both the 13" & 15" 2016 & 2017 all of a short backlight cable issue (FlexGate). The 2018 and onward systems don't have that issue. So if you have either I would press Apple hard to get it fixed. But sadly, the window is now closed on the 2016 models and the 2017 will also end shortly. Thats not to say its not repairable its just going to come out of your pocket vs Apple's!
Basically, the OP's damage is do to a persons actions not a engineering failure!
댓글 달기
귀하의 답변을 추가하세요
suetin085 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 44
전체 시간: 868
