MacBook wont start after battery replacement
Hello! I have a 13’ Macbook Pro Early 2015 model. I replaced the battery with iFixit parts and tutorial but after finishing the replacement, I tried to start de macbook and nothing happened. I connected it to the charger, and it starts with a green light and then turns orange, but it wont start up connected to the charger. I tried disconnecting the battery and it wont start either when connected to charger. I tried all the suggestions I found on the forum but didnt work ( resetting SMC, and all that).
thanks in advance!
좋은 질문 입니까?
댓글 5개
Let the battery charge up for a good 8 hrs did the MagSafe change to Green from Amber? If not contact iFixit for a replacement battery,
Dan 의
@danj Thanks for the reply! It did change from green to orange. Will leave it overnight to see if charging helps. I’ll let you know
Bruno 의
@brunop182 - Any news?
If you can install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Dan 의
@danj Yes, I took it to a professional technician and they told me it was the logic board which was fried, probably because the new battery did something to it. So now I have to change the logic board, which is not a cheap part. I´ll let you know if it was indeed the logic board when they fix it.
Bruno 의
@brunop182 make them prove to you it was the logic board. like what troubleshooting steps they did to figure that out.
Logixal 의
