a10s will not turn on
samsung a10s will not turn on and will not changer too
좋은 질문 입니까?
Remove the back and disconnect the battery reconnect the battery and plug the charger in.
해당 답변은 도움이 되었습니까?
hello as i owner of this phone i have dealt with the same problem if i press the power button nothing happens i can still unlocked with my fingerprints it will unlock. If your phone is power off and you want to turn it on get your laptop,pc,mac and press the volume up and down button and plug it in the pc when it turns on press the volume down button it will restart and herre you are fixed i hope i have helped you and thank you and thi problem is caused by watter getting in the power button it happens
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 4
30일 전: 17
전체 시간: 1,492
댓글 3개
Hello,
Did anything happen to cause the error?
Adam Gari 의
What was happening before it did this? Did it get hot? Make any noise? This post is not descriptive at all.
Duck 의
my phone will not turn on with the on button
kelli amedu 의
