주요 콘텐츠로 건너뛰기
The Backbone One is a mobile game controller for the iPhone. It was released in October, 2020.
Can the Backbone One be modded for an iPad mini?
If you remove the springs, can it stretch to fit an ipad mini5?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
Hi @clatekeen, after removing the spiral springs and the screws which connect both controller sides, the Backbone One can be extended by a maximum of 19cm. (7,5 inches).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
So if you remove the springs and screws that control the middle back piece, you can remove the main connector cable, and unfold it. In that configuration it can be modded to fit an Ipad mini. However it cant retract, and it’s easy for the main cable to pop off, but it does work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
clatekeen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 55
전체 시간: 4,279
