주요 콘텐츠로 건너뛰기
Repair guides and support for the Lenovo Ideapad 310-15IKB, a midrange consumer laptop released in 2016.
3 질문 전체 보기
HDMI port repair (general question)
Hi there!
So the HDMI port on my laptop stopped working, and a USB to HDMI adapter does have a terrible framerate. Its not a good solution.
The question is, how hard is the fix. Is it even possible to just replace/re-solder the old port? I did not find any good guides - i would make one.
Just need some motivation here ^^
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Soldering a motherboard requires experience. It could irreparably damage the board and you should buy another one. If you have experience, look at where the connector is located and if you have small components nearby. It is one of the easiest parts to change in this type of repair.
Lucky!
댓글 달기
답변 1개
가장 유용한 답변
It depends on whether you HDMI port is on a daughter card, or part of the motherboard. If it is on a daughter card, then repair is often simple and you can just replace the pcb. But if the problem if with the motherboard (like with the hdmi controllers, or if the hdmi port is soldered directly to the motherboard) then it might be more difficult.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Prokrastinator 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 241
