주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
replacing screen adhesive strips
do you attach the 3M strips to the glass or case,
And is there a guide to the placement of each strip
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Replacing screen
martinezramon974 do you need help? if so please post a detailed Question on the question form
댓글 달기
답변 3개
가장 유용한 답변
I had huge problems after replacement to fix the frontpanel well. Maybe because of this the gave me two sets of adhesive tape... So anyway better to use two layers of the 3M tape if available...
My final solution after bad sticking frontpanel was at the end to use silicone sealent... now it sticks perfect and works also as a good sealing for dust...
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
What kind of silicon sealant?
댓글 달기
Here is the guide:
http://ipadscreenrepair.com/repair-guide...
Scroll down on the page for adhesive diagram.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
here is the placement of the pre-cut 2 sided tape for ipad 2
[http://www.ipadscreenrepair.com/wp-conte...
it is very cheap and easy...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Gary Kukulka 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 18
전체 시간: 44,259
