주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Camera and screen not right
i purchased the Ifixit battery and camera for my GF’s iphone. i replaced them both on Sunday. following the instructions in the guide on this page. now the new camera does not show an image and doesn’t seem to take photos when i press the capture button. in addition, the screen gets white vertical lines when there is anything white on the screen in the horizontal pixel path. i have done the entire replacement 2 times now thinking i have done something wrong but same result. everything works, and i can still see what is on screen its just white washed. i know reading a previous question that plugging in the battery last is the fix but has not worked for me as thats how i did the install both times.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Hi,
Have you tried resetting the iphone ?
i haven't as of yet, i have qued the GF to get her stuff backed up before we do, shes slow at these type of things
댓글 달기
답변 1개
Hey bro, I would try to take it back apart and check your connection of the display to the main board. the screen has to be backlit and that is what allows you to see whats on it. if you can see the screen faintly then it’s getting the display information but with out being backlit you wont be able to read it. Most screens have a separate power inverter to handle backlighting.
Update (05/05/2021)
If you can check it against a known good screen, You might have gotten unlucky and just gotten a bad screen. good luck. I would call and get a new one if you dont have luck soon.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
it is the original screen i replaced the battery and back camera. the screen works and is completely readable. the white lines are faded but i can still see the image underneath. when you first activate the screen after a lock the screen is normal. the lines slowly bleed in and if you change the screen the white lines change position. it seems to be connected to any white projections created, where ever the horizontal white pixels are active the intersecting vertical line becomes a faded white overlay from top to bottom of the phone.
Hmm….Does not sound like any pixel burn out I’ve heard off before. Have you any other way to test the phone it’s self?
댓글 달기
답변을 추가하세요
Scott Ferguson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 34
전체 시간: 134
