주요 콘텐츠로 건너뛰기
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
70 질문 전체 보기
Replacement screen not working properly for dimming below 30%
I finally installed my replacement screen from ifixit yesterday, double checked it worked by turning on the device, before I glued it in place. Unfortunately I did not check the screen functions more thoroughly. When the screen brightness dips below 30% the backlight doesn’t continue it's gradual dimming, but shifts to a dark reddish hue making the screen unreadable at low brightness. Is this a known issue or easy to fix? May it be because of a faulty connection between the screen and the phone or is it a defective screen?
Thank you in advance for any assistance on resolving the issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Sounds like it could be one of the following:
Bad connection - Reseat LCD ribbon cable
Backlight circuit damage - Caused during the repair would need to be tested with the multimeter
Or and god forbid it, but maybe the screens a dud. 1 in every 10 screens we buy-in for our customers seem to have a slight defect or just dead on arrival from the suppliers.
I would try reconnecting the LCD first, give the phone a force restart, this can help. Then put a support request in with iFixIt, while you wait, see if you can find a bad backlight circuit on the board, if there is one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Martin Fischer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 14
전체 시간: 172
