주요 콘텐츠로 건너뛰기
A2116 / 2019 / 3.6GHz 쿼드 코어 i3, 3.0GHz 6코어 i5 또는 3.2GHz 6코어 i7 프로세서. 2019년 3월 19일 출시.
78 질문 전체 보기
Machine is powering on but no display
During OS(Big Sur) updation suddenly light goes off. After few minutes we have tried to powering on the machine then we have found machine is powering on but no display. We have replaced the RAM and Hard drive but problem not resolve.if any one have any solution
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Ouch! I suspect you where a bit too quick!
During the OS and update processes your system will often appear off, in truth its just not able to display anything as the systems firmware (EFI) is being updated. So what you’ve now done is corrupted the process and pulled the chair from under the system to boot replacing things!
OK, so the firmware is in never-never land which we need to fix. At this point I would carefully put everything back together making sure the system does not look shop worn so Apple won’t object.
Now its time to visit an Apple Store or authorized service center with your system as being the best course.
So is there anything I can do my self? You’ll need to replace the logic board Apple has altered how EFI is setup on the newer systems and using a custom chip.
I have not been able to get the needed chip as well as the firmware. As such you can’t replace the chip with the needed firmware on these newer iMac’s. Apple has made it much harder to fix a simple issue like this. While still not an easy fix as you need to desolder a chip off the logic board and replace it at least it could be done.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Moinul Haque 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 90
