주요 콘텐츠로 건너뛰기
My battery corroded the main connectors. Can it be repaired?
While in docking port, ERR 3 the battery corroded the units main charge connectors. I tried reaching it with q-tip with vinegar, but it qasnt enough so it will require a full breakdown. Do you repair?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
almost anything is repairable. 1st, can you get the parts required: 2nd can you get the tools required: 3rd can you find directions needed:
For battery contacts, vinegar and sandpaper work unless the contacts are eaten away.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robin Harper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 225
