주요 콘텐츠로 건너뛰기
Repair and disassembly guides for GE Microwave ovens.
349 질문 전체 보기
Microwave heats but no lights, fan, or turntable.
A bulb socket burned up in my over the range microwave and now the other overhead light and interior light don’t work. Also lost fan and turntable. But the unit still heats and the timer works. Any ideas? I was hoping to see an obvious fuse or relay but I’m no expert and don’t see a fuse other than the main 20A which is fine.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
There should be atleast one more fuse inside the houseing should be alot less amperes than 20.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
MOST MW problems are due to loose push on connectors. Sometimes those connectors overheat and burn the insulators and/or wires. It does not usually affect lights due to lower current, but it is a common failure point. Any lower current fuse would generally affect the electronics.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
DeAnne Morris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 207
