주요 콘텐츠로 건너뛰기
The Bose SoundLink Mini II is a Wireless Bluetooth Speaker that delivers high quality audio from a compact design. The device weighs approximately 1.5 pounds and has a Bluetooth range advertised up to 30 feet. The device was released after June 26, 2015 and is Identified by model number 725192-1110.
There is little or no response from the buttons
I get a small flash of light from the power/charge indicator when I disconnect the USB Charger. I get similar response if I disconnect the cradle supply but only if the USB is plugged in as well. Some devices see the Bose through Bluetooth but do not connect.
Battery tests good.
The speaker doesn't power on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Did you tried this solution?
Bose Soundlink Mini II Microschalter / Tasten Reparatur
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Paul Lakin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 88
