주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Charger port works when part is tested, but not when in the phone?
I just bought an iphone7 to repair and I am a little confused by what this one is doing.
When I received the phone it was stuck in a boot loop and wouldn’t recognise the charger. I disassembled the phone and plugged in only the screen, the charge port and the battery to test it. It booted OK into setup, the phone was charging fine, and it was recognised by iTunes.
I have put it all back together and now the charger doesn’t work again and iTunes doesn’t see the phone.
Setup process works fine until it gets to the Data & Privacy setting and then it hangs.
Will replacing the charger assembly likely help?
Have I mangled something putting it back together?
Has anyone else had this problem?
thanks for your help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Before purchasing any more replacement parts, take the phone apart again and get it to the state you knew it worked in(screen, charge port, and battery only). If it's not working now, then you've damaged something putting it back together, but if it does work, you can continue to the fun part!
Simply put it back together one part at a time and keep testing it until you run into the problem again, and then you'll have found the part that causing the problem. Sometimes it can be something like a camera that is causing these issues so plugging in each component one at a time will allow you to find out which part is the problem, even if it might take a while to do so...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Edward Hillman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 13
