주요 콘텐츠로 건너뛰기
냉장고, 냉동고 및 냉장-냉동고를 포함한 식품 냉각 장치 수리 및 분해 안내서.
1696 질문 전체 보기
Have to keep replacing water filter.
Hi,
I have a Frigidaire refrigerator bought in 2015. Earlier this year in January, the water dispenser stopped and ice was not being made. I replaced the filter with another Frigidaire one and it worked again. 3 weeks later it stopped, so I bought a 2-pack of off brand ones. Replaced it again and it worked for another 3 weeks. Now it stopped again and replacing the filter makes it work again right away. I can’t figure out what the problem is and why the original filter, no longer available, worked for 5 years without any issue. Please advise. Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Hi Mike!
I think that problem is with limescale depositing on the pipe walls - especially if you have hard water.
For 5 years it’s possible that limescale stucked in pipes in refrigerator.
Try to get to pipes and clean them.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The replace indicator on most, if not all, refers is a timed function. With 2 seniors in the house we don’t use much water, but the timer does not wait for us. As such, blocked pipes are not going to trigger it. The timer circuit is probably on the control board and is probably controlled by a capacitor that is going bad therefor reducing the time to 3 weeks instead of 6 months. If you are into fixing it you can eyeball the board to see if any of the cap tops are starting to become convex. They must be perfectly flat or slightly concave. Removing a filter and reinserting the same filter will prove the point.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mike Zee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 27
