주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
MacBook does not boot and kernel panics. FIX?
Hi,
I have a 2010 13” 2,4ghz MacBook Pro. The computer does not boot and would kernel panics usually. Here is every OS I tried
Snow Leopard Installer On USB : Goes to Apple Logo and tries to boot but kernel panics halfway.
Yosemite On Internal Drive : Boots halfway crashes and has shows some error log text and has a “NO” sign a few seconds later (occasionally kernel panics)
Yosemite On USB: Same issue as internal drive
Yosemite Install USB: Boots, but “unmounting disk” error when installing
This computer seems to be very tempermental. I gave up and came to the answers community instead. I also tried to reset the PRAM and Option+D and Cmd+R. I don’t know about the logic board. I took the computer apart and I didn’t see any problems. And also the fans run at full speed for some reason, Just a side note. And also I am not using AASP’s. I have already wasted enough time there. Thanks guys!
UPDATE : 5/18/2021
I tried yosemite on an USB and now it will only go 20% in the apple logo progress bar and it will just stay like that forever and doesn’t go any further.
After trying Snow Leopard, the internal drive doesn’t work. I think it’s the SATA cable, but I am not going to fix it until i can get the computer into an operating system. The computer also doesn’t accept : Option+D and Command+R for some reason.
UPDATE: 6/2021
The laptop did boot into every version of macOS using safe mode, but only El Capitan/Lion works using normal mode, but it is EXTREMELY laggy and unusable? Can I still revive this motherboard?
And also the battery doesn’t work, just another side note
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
The panic report often gives clues on what the issue is, I would review it.
Also I would run the on board diagnostics. Restart your system and press the D key to enter.
@danj It will just say the normal panic. It will just stay like that forever
@danj the computer also would not boot from a working copy of Yosemite for some reason. It would only go to 20% and stay there. I wonder if the MOBO (Motherboard) is still fixable.
댓글 달기
답변 1개
선택된 답변
Try running with one SO-DIMM swap them around and try both socket slots
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
thanks, but no it didn't work
@rs1020 - At this point Its time to try a fresh drive, you'll need a fixed speed SATA II (3.0 Gb/s) drive which are now getting hard to find or you'll need to get a auto sense drive like the Samsung 870 EVO note the interface line lists 3.0 Gb/s (SATA II) make sure what ever drive you get lists your systems speed, if it doesn't it won't work properly in your system.
@danj yeah much faster now! thx very much
@rs1020 - Happy to hear the issue was the drive! Don't forget to score and accept the answer - Thanks!
댓글 달기
귀하의 답변을 추가하세요
ryoseo1020 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 232
