How can I fully teardown the keyboard (removing the pcb from the case)
Most teardowns I can find only remove the top half from the bottom.
I have yet seen a teardown where the pcb is removed from the top half of the case.
좋은 질문 입니까?
좋은 질문 입니까?
I have not seen any that could not be separated from both top & bottom. You just need to find the screws holding the PCB to the top.
해당 답변은 도움이 되었습니까?
All the ones (many) that I have taken apart, the bottom comes off first. Then PCB is removed from the top. If it is a contact type, the keys remain in the top. If it is a switch type, they are all attached to the PCB.
When I disassembled my G915, I could never get the front part off. It looked some of the buttons had a different design than the others. They appeard to be mounted from the top and soldered to the board, locking the top in place. I may of course have missed something, but there were NO more screws to remove and the top was firmly in place all across the board (not just in one place).
해당 답변은 도움이 되었습니까?
Did you remove the tiny screws under some of the kaycaps?
24 시간 전: 4
7일 전: 6
30일 전: 47
전체 시간: 1,963
