주요 콘텐츠로 건너뛰기
Technique for replacing belt
Have this Hilti DSH600X power saw. Been trying to replace the drive belt . It's a serpentine belt. Been trying to heat it in hot water so i can stretch it enough to roll over the front blade pulley. Just can't do it. Wondering if there is an easier method? Can't find any adjustment screws or slide. Anyone know about this?
Thks, Charles
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 3개
선택된 답변
I did two of these belts I used long 3/8 extension One end of the extension on the pulley nut with the belt on extension and stretch You got tie the saw down so it won’t move you really got to stretch the belt
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
So pretty much, Hilti wants you to send tool into them to do any maintenance.
Thank you I will try that!
댓글 달기
Think about this. The mfg put it on with ease, you should be able to also. The has to be an adj since belts stretch.
This is for a Stihl but I am betting it is similar https://www.youtube.com/watch?v=a7cydlI8...
Or you could go here and chat with Hilti customer service https://www.hilti.com/content/hilti/W1/U...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
What is the belt number that fit the dsh 600x concrete saw
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Charles Goossen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 43
전체 시간: 2,192
