주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Wont charge and heptic feedback of home button does not work
After replacing the screen assembly and lightning connector assembly the phone wont charge and home button feedback does not work.
Otherwise phone seems to work OK.
I checked all the main connections,but the problem remains.
Any suggestions?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
It sounds to me that the replacement part you have is faulty. Have you also checked to see if the speaker is working? If not then its definitely defective as all those components run off the charge flex.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thank you for your reply.
Speaker is working fine.
All the replacement parts were ordered thru ifixit.
Do they have any tech support I can contact with my problem?
I' ve linked the support page for you; https://help.ifixit.com/collection/130-c...
Thank you:I have contacted them and provided all the photos they asked.
They are sending the new components needed.
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Butrus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 34
