주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서. 이 내용은 2006년 초부터 2007년 중반까지의 최초 Intel 기반 Mac Mini 모델을 다룹니다.
PRAM Battery Not Working
A Mac Mini I have wasn’t saving the date and time/wifi so I ordered a new PRAM battery. I put it in but the date and time/wifi still isn’t being saved. I flipped it around but the same issue occurred. I have pushed the metal fingers as close to the battery as I can, yet it still wiggles a little bit, so maybe that’s why? I tried it on another A1176 I have and the same problem.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개:
What is the batter markings?
It sounds like you either got the wrong one or its bad
의 공유
@danj I bought the ones that were in the guide
의 공유
@Jordan Baron - What is the batteries markings?
의 공유
@danj Energizer CR2032
의 공유
@Jordan Baron - Well, that's the correct battery, why I pressed was there is a thinner battery which is only 1.5v.
Your comment "yet it still wiggles a little bit" made me question if that was your issue. At this point your logic board socket maybe damaged as the battery is firmly held.
의 공유
댓글 달기
답변 1개
Before you return what sounds like a bad battery, open up the date and time preferences and make sure you have the “set date and time automatically” checked.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jordan Baron 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 434
