주요 콘텐츠로 건너뛰기
Repair guides and support for Dell Netbooks, a class of small, lightweight laptop computer from the late 2000s.
My Inspiron 7579 is crashing. Help.
The computer is crashing and BSOD always shows up. I’ve tried blowing on the fan, but it didn't help. help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Provide a image of the BSOD or the error code, photo would be more useful
댓글 달기
답변 3개
선택된 해법
BSODs are usually software-related. Try resetting your computer by going to Settings -> Update & Security -> Recovery. Under the Reset this PC, choose Get started. Follow the prompts.
This will remove your apps and settings, but may prevent further crashes.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I am going to say that by you laptop crashing, then it does come up. If so go to Event Viewer and then Window Logs and see what might be causing the issue. Also the BSOD error would be helpful. Check to see how much RAM you are suppose to have verses how much RAM your system is showing you have.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
First take a data backup of your important data now try reset the settings of your laptop as it was new. If it didn’t work then just change the window of your laptop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
normal person 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 194
