주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 Time Capsule, 모델 A1355. 2009년 10월 출시.
How do I replace power supply with external supply?
In the Time Capsule Overall page it says under upgrades:
Power Supply:" You can replace and or repair the power supply or remove the current power supply by adding a stand-alone power supply.
But there is no information on how to do this. The Model 1302 section says how to take the supply out, but not how to fix / replace it. I was given a 1355 that supposedly worked but I get no LED when I plug it in, so I suspect a power supply issue. How do I hook up an external supply either permanently or to verify that the rest of the unit works?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
https://sites.google.com/site/lapastenag...
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Very good description of how to fix as far as I can tell. I'm not sure if I still have unit, as it's been a while since I asked, and I may have gotten rid of it. If I can find it will give this a try
의
Unfortunately the website in this answer is no longer active.
의
That's not a problem ;-) check it here:
https://web.archive.org/web/202103141628...
FYI: web.archive.org has many of the webpages that are no longer active.
Cheers!
LDS (LazyRock)
의
댓글 달기
답변을 추가하세요
Arthur Torrey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 33
전체 시간: 1,778
