주요 콘텐츠로 건너뛰기
Repair guides and technical knowledge for the Xiaomi Mi Mix 2, released in 2017.
14 질문 전체 보기
How can I check whether my charging port is broken? (Xiaomi Mi Mix 2)
Hello there!
I have a problem with my current Xiaomi Mi Mix 2. I does not charge. I suspect that the charging port is the cause of the problem since I have had problems with it before.
My question is how can I check whether the charging port is really broken or if the problem is somewhere else.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The easiest way would be to buy a little USB Amp/Volt Meter and plug it into the wall and then your charger cable into that and it will let you know if the charger is drawing amps or not. If not it’s most likely in need of being replaced.
The meters are less than £5 if you look around…
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
BugReport Plon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 220
