3 different power supplies spark when plugged in
I had a TV that had grounding issues and fried an HDMI cable along with a cable box. Xbox was plugged into the TV when it happened and refused to turn on after. I have since purchased 3 different power supplies and every single one shorts when I try to measure power output with a multimeter. I’m sure I have the proper settings on the multimeter and a properly rated power cable, yet every single time the power supply shorts and there is no output reading. Am I just having bad luck with parts or is it something else?
좋은 질문 입니까?
so without plugging it into a TV it shorts out a PSU?
this only started when you plugged it into the HDMI on that faulty TV?
Logixal 의
The first time the Xbox stopped working it was plugged into a bad TV. Since then I've gotten rid of said TV and have the Xbox on my desk where I attempted to repair it. I'm nearly certain there are no other issues with the Xbox, only the power supply. However every time I've bought a new one it's shorted out as I try to measure output with a multimeter. I have properly rated power cables, but it's not working and I'm nearing the end of my rope with this repair.
radioappleman 의
So, the shorting of the PSU is entirely separate from the TV issue. I'm just questioning why they are shorting, whether it be bad luck with parts or something else.
radioappleman 의
Are you absolutely sure that your leads aren't causing the short?
brandon k 의
Well it turns out your were right, my multimeter is busted. Thanks for the advice, will be buying new psu and multimeter
radioappleman 의
