주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Used isopropyl alcohol to clean charge port iPhone 7now won’t turn on
use the isopropyl alcohol to clean charge port of iPhone 7 because there was something stuck in the port it turned on fine but after leaving at Charging for the night it will no longer turn on. The alcohol may have got into the speaker. i used 99%.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
i use 99% IPA all the time. for external cleaning, i always wait for full evaporation, sometimes i speed things along by putting it in my "server room" (i have a closet with a 24U server rack which generates a fair amount of heat). if i soak components in it, i'll leave it in the server room overnight before reassembling. given what you've stated though, there shouldn't have been any issue, even if some alcohol got into the speaker.
what i do need to ask is
1) how was the IPA applied? specifically was the bottom part of the phone dunked into it?
2) how as the port cleaned out? did you use a toothbrush, toothpick, metal dental tools?
if you have the tools, can you remove the pentalobes and open the screen to fully let the innards dry out?
unfortunately i'd need more details to come up with other ideas
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
oliver crancher 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 31
