주요 콘텐츠로 건너뛰기
독일의 자동차 그룹 BMW가 제조한 자동차 수리 안내서 및 지원.
204 질문 전체 보기
2007 328i bmw and I can’t get my car to turn over
I actually have a 2007 328i bmw and I can’t get my car to turn over it died at the gas station had to have it towed back home and it has been sitting since over a month now I need help. The dashboard shows a car on a lift and and a coolant type picture I don’t know what to do I tried to clear it with icarsoft obd2 code reader but it’s still a no go
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
if there’s lights on the dash indicating an issue then get a diagnostic tool plugged in, lots of BMW’s once these lights are on won’t allow you to start the car for safety reasons probably to protect the engine. BMW specialist or a in depth diagnostic tool to read it before taking any guesses rather than a standard OBD tool, The light comes on for a reason, clearing it won’t do anything other than just come back on and cause more damage more than likely continuing to drive it. the icon with the car on a lift is an indication built in to the car meaning it is due for a service, if it hasn’t been done recently may explain why the coolant light is on too.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
you have not done a thorough analysis or have not communicated all that you did.
For starters, “not turning over” would indicate the engine isn’t moving as opposed to “not starting” which would indicate the engine is trying to start by ”turning over”.
If it is not turning over then you must listen to see if you hear the starter solenoid working and pulling in the gear to the flywheel. If you don’t hear that, then a battery test is in order. If that is good, then you must determine what is wrong with the solenoid == wire, connection, solenoid, or ignition key or circuit.
If it is pulling in and the starter isn’t running, then either, the starter relay which is part of the solenoid/starter assy,, the starter itself or the engine is frozen up. A frozen engine would be indicated by severe dimming of lights when the starter engaged since it draws significant current when locked.
HOWEVER, with the dash indicator you are getting, you may have a coolant sensor that prevents the car from turning over if the water is low or the sensor is bad. You will have to research that.
I would recommend doing a little more analysis and searching for a BMW forum to ask the question.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Michael Tetu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 63
