주요 콘텐츠로 건너뛰기
모델 A1046 또는 A1095 / 1280x854 스크린 해상도
118 질문 전체 보기
Laptop screen is black, can anyone help?
I dropped my laptop now the screen is black. It still powers up and sounds like the hardrive is spinning. I tried connecting it to an external monitor through the dvi and did not work. Can anyone help?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
선택된 해법
Oh ouch. If connecting to an external monitor didn't work, things could either be very bad, or not so much. If no external monitor is working, it usually means that your graphics card some how got messed up, instead of you actually breaking your LCD screen.
I'm pretty sure the graphics card is soldered on for your laptop, so while you don't want to take everything out, you might try lifting up the top of your case, following this guide, and see if anything is out of place or disconnected.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
A dropped computer could easily have hard drive problems--have you tried booting with your system disk and running disk repair? Nat's suggestion about looking for a disconnected cable is certainly something you would want to do. Good luck Ralph
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
todd 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 3,631
