주요 콘텐츠로 건너뛰기
2018년 애플 11월 스페셜이벤트에서 출시된 태블릿컴퓨터 고유번호 A1876, A2014 및 A1895.
64 질문 전체 보기
My iPad pro 2018 12.9" lost backlight
Hi all, this is my first post. My iPad pro 2018 12.9 inch (model 1895) went black during usage outside at 28°C. Then I noticed that the actual display shows picture but the backlight is not illuminating any more. I have opened the iPad and checked the logic board for visual damage but everything seems to be OK. The filters next to the display connectors are also ok. Does someone has experienced this issue or has the schematic for my ipad? Would be very helpful
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개:
How did you test the filters
I have used this video as a guide: https://youtu.be/6FnO1oY-voM
It is not the same model but has a similarly design at some circuits.
I did not had any burned filters but found a burned cap (optical burned but not shorted).
Do you have a multimeter
Yes. Do you have schematics available for this model which is showing where the backlight circuit is located?
댓글 달기
답변 1개
The backlight on the screen might of failed or the backlight circuit failed on the logic board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Serdar Yagcioglu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 1,080
