주요 콘텐츠로 건너뛰기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
69 질문 전체 보기
MacBook Pro screen slowly turns black after leaving it on for too long
My MacBook Pro recently screen slowly turns black and has overlay of whatever the windows are on the screen even though it is minimized. However if I use external monitor the external monitor shows without error.
Tried following methods but still NONE are working.
  1. Check Mac's Battery
  2. Restart Mac
  3. Restart Mac with Specical Keys
  4. Reset the NVRAM/PRAM
  5. Disable Suspicious Login Items
  6. Safe boot
Firstly it was completely black. Then after restart a few times, it only shows the top bar
The screen then slowly recover line by lines but still have the overlay issue. Here’s a video of it.
https://drive.google.com/file/d/1G-8awwX...
Then I shutdown the MacBook for a day and it works fine after that. However the screen slowly turns black again with some horizontal and vertical black lines if I leave it on playing some youtube music.
May i know how can I fix the root issue and how to prevent it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Hello! Can I ask what you did? because I think mine did the same thing after I left it on for too long playing something on YT. I really need help :(
댓글 달기
답변 1개
선택된 답변
You need to get to an Apple Store or authorized service center to get your system fixed ASAP! Depending on when you bought your system and where your warranty coverage could expire very soon if not already!
Your display assembly has failed! And you need to get it replaced. Its quite expensive so you really want Apple to pick up the costs here. Don’t let this slide!
OK the why! I suspect your displays T-CON board overheated because the vents where blocked or the fans failed. So the needed cooling was not available. Using a good thermal monitoring app like TG Pro can be helpful in watching things as well as allow you to trigger the fan to ramp up when things are getting toasty!
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks man. However in my country is still in MCO. All the repair shop are closed and unable to visit. Anyway, my warranty had expired last yea. I hope it wont be a huge cost for me.
@sam.g30003 - I wouldn't discount getting it fixed under warranty quite yet! Call Apple to arrange a shipping box so you can ship it to them. Otherwise it will cost you somewhere around $700 - 800 USD just for the part!
댓글 달기
귀하의 답변을 추가하세요
sam.g30003 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 28
전체 시간: 621
