주요 콘텐츠로 건너뛰기
닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
706 질문 전체 보기
C-port replacement and PCB mounted pads
Hi all,
I have a butane soldering iron, removed the cport as carefully as possible using the heat nossle.. I think I might have damaged the pads or they're lifted.. The pads are yellow/copper and not without solder like most of the videos.
I may have damaged the board, I'm not sure.
Can someone please assist with looking at the pic and advise if I can proceed to mount the new port and tips on how to get solder to stick to the pads.
Yes bridging on some of the pads, will clean those with copper/flux.. I have petroleum jelly btw and have concerns bout the GND pad next to mounting hole..
Thank you.
Newb solderer
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You have ripped every solder trace from the board. It might be repairable by an experienced technician but will definitely cost more now to repair than it would have done.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Bah.. I knew it didn't look and feel right.. Yes very useful thank you.. Dan.
댓글 달기
귀하의 답변을 추가하세요
Vector Taitoko 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 74
