주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
Laptop dies when unplugged
I replaced the battery in this MBP just over a year ago. It now shuts off immediately when unplugged and Coconut Battery registers no battery at all.
Does this indicate a faulty battery or a logic board problem? The latter seems more likely to me, but I’m asking because a battery for another computer of the same model that I ordered from iFixit around the same time last year also recently turned out to be faulty.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Thanks Dan. Just added the CoconutBattery shot.
댓글 달기
답변 2개
선택된 답변
Sadly your battery is bad! The micro-controller within it has failed so the communication to your system is not working as well as the charging of the battery.
Time to replace it! I would contact the seller to see if they offer a warranty. As an example iFixit offers a year.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Try replacing the battery again. If that doesn’t do the trick, that is when you should either replace the logic board or the whole MacBook altogether.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Let's first diagnose the issue before we go that far!
댓글 달기
귀하의 답변을 추가하세요
thardee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 6
전체 시간: 38
