주요 콘텐츠로 건너뛰기
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
Re-Installing OS and Spinning Wheel Is Frozen
I was given a 2008 Mac Pro today. I put a hard drive in it, made a MacOS USB Drive and tried to install the OS. Upon booting from the USB, I’m greeted with the normal Apple screen. The spinning wheel shows up, spins a few times , stops and doesn’t proceed any further. I have tried zapping NVRAM, re-downloading and remaking Installation USB, tried different USB drives, swapped RAM modules and still the same. I am attempting to install OS Mavericks since I know it supports Early 08 and up.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 7개:
What is the drive you put in? Make & Model
It is a WD Blue 500GB
Is this the drive: WD Blue
It's an older WD Blue
@goetzsage2 - Can you give me the model number of the drive.
댓글 2개 더보기
댓글 달기
답변 1개
Why I had asked is many people forget the older Mac Pro systems SATA ports can only support SATA II (3.0 Gb/s) or SATA I (1.5 Gb/s) drives. The newer fixed speed SATA III (6.0 GB/s) drive are not able run in your system directly. You would need a PCIe SATA board.
Are you able to setup the drive externally on your other Mac system using something like this: Universal Drive Adapter
Turn your current hard drive into an external drive with this adapter. 이미지
제품
$24.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
goetzsage2 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 234
