주요 콘텐츠로 건너뛰기
Apple이 제작한 4세대 무선 키보드입니다. 2015년 10월에 출시되었습니다. 모델 A1644.
48 질문 전체 보기
1 and 2 keys stopped working
I just recently acquired a pre-loved late-2015 21.5 iMac with A1644 keyboard. All worked 100% till just now when the 1 and 2 numeric keys stopped working. Not on their own nor when combined with shift. No liquid spills or the like. The overall condition of all components is like new - extremely well looked after. I’ve given it a shake, light tap in an attempt to dislodge whatever could possibly be stuck underneath it, but to no avail. Please help…
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I have the same problem. I disassembled the key to see if there was something damage. I could not retire the plastic bublbe, so, as far as I could see, there was nothing damage.
Solution: remap the keyboard using Karabiner-Elements assigning 1 and 2 to the F1 and F2 keys.
It would be interesting to know the reason of the failure, but I couldn't identify the root cause.
댓글 달기
답변 2개
가장 유용한 답변
You could try replacing the key parts if you think they are bad Magic Keyboard parts
If the issue is within the lower sections there is little you can do as Apple doesn’t make the part repairable. At which point your only hope is to find another keyboard.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Niel Burger 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 170
