주요 콘텐츠로 건너뛰기
2.3L 4cyl or 3.0L V6, 6th Generation
427 질문 전체 보기
2001 honda accord - green key light on dash does not always come on
2001 honda accord - green key light on dash does not always come on. When it comes on the car will start. If it doesn’t come on it will not start. Never can tell when it will come on- its intermitent. Car has died only 2 times while driving. I have 4 programed keys and it happens with all the keys (its’ not the chip in the key)
i think it is either the immobilizer, steering switch, or is it some random ground problem.
Anyone have any idea
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
When the car died while driving... was that from the immobilizer?
댓글 달기
답변 3개
가장 유용한 답변
the chip in the key is a transponder and there is also one in or around the barrel or behind the dash and the frequencies marry up to each other in order to start the car and does hand in hand work with the immobiliser so the transponder in the car may be a possibility don’t rule it out fully. could be faulty wiring or water getting into the system. if that green key light is on and off intermittently my guess would be loose wire or water shorting something in the system every so often which is immobilizing the car and that’s why its shut off whilst driving but not all the time
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It's theft perfection look on you tube and reset theft perfection forget how but lots like turn key in driver door like 3 time one way and the other then other way and it will reset theft pertection
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Green light will come on when I beat on the steering wheel
Yes my honda dose that some of the time a hello did you fix it
댓글 달기
found a print circuit board on your immobilizer relay underneath the dash by the steering column black relay single plug had to we solder print board where the two relays contact to the board to resolve problem
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
mary 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 33
30일 전: 102
전체 시간: 4,991
