주요 콘텐츠로 건너뛰기
Twentieth Anniversary Macintosh는 Apple Computer, Inc. 회사 설립 20주년을 기념하여 1997년에 제작된 한정판 개인용 컴퓨터입니다.
Replace hard drive in TAM
My TAM is no longer recognizing the hard drive. It boots up with the system/floppy disk icon with a “?” Using the software CD neither Disk First Aid or Disk Setup show the hard drive as part of the setup. I’m assuming I have a bad hard drive or something wrong with the boot sector.
Do you have the guide on how to replace a hard drive in the TAM?
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Accessing the hard drive is fairly easy on the TAM. There are two tension clips near the bottom of the back which will let you lift off the cover (this is shown in the logic board removal guide). At this point you are basically looking at the drive. It is mounted horizontally, on top of the processor heatsink. It has a small assembly with a fan that is held on with four Phillips head screws. Remember to remove the fan connector as well.
The drive is just a standard issue IDE laptop drive. You can find one in most late 90s and early 2000s laptops. Booting from a system disc will let you initialize and format the drive. Even if it's 40GB your Mac will likely only see 4.5GB (this is normal and there is more nuance on this topic). The screw holes might not line up on the bracket so you may need to be a little creative. But as long as the pins align you should be in business for very low $$.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Micheal DiPaolo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 464
