Replaced battery but computer still takes forever on simple tasks
The battery you sold me makes my computer do wonky things now. Can't do simple tasks….
좋은 질문 입니까?
좋은 질문 입니까?
Let’s run the onboard diagnostics to see if any errors pop. Restart your system and press the D key to enter
Reference: Mac startup key combinations
If that doesn't show any errors then I would replace the HD SATA cable as they do fail quite a lot! Your Hard Drive Cable Is A Ticking Time Bomb
So I would place a strip of electricians tape down to help isolate the cable from the rough aluminum surface but I would still replace the cable MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and here’s the guide MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
Make sure you don’t crease the cable as that to will damage it!
해당 답변은 도움이 되었습니까?
Also, I would check to see how much storage space is left on your HDD or SSD. A drive that is running out of storage space can slow down your whole system.
Paulette.
I don’t think changing the battery for the laptop will increase performance. you might want to get new ram or upgrade your ram and possibly get an 2.5 sata ssd.
해당 답변은 도움이 되었습니까?
Actually, replacing a laptop's battery can be very substantial to its performance, especially in MacBooks. This is because MacBooks will start to throttle their performance when their battery starts going bad. They do this to protect their internal components from not getting enough power from a bad battery. In this case though, it would appear as if the battery might not be a culprit after all.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 38
댓글 1개
Hello! When did you replace the battery in your MacBook Pro? Also, was the computer slow on simple tasks before you replaced the battery?
Bob Singer 의
