주요 콘텐츠로 건너뛰기
Support and repair information for Beats Solo3 headphones.
Doesn't turn on but flashes when charging
Hi there, I've had my beats for around 2 years now, yesterday at 7pm I was using them perfectly fine with no problems at all, and then when it came around 11pm it turned on but then shut down after a few seconds, when I put it in charge it shows 3 bars and one flashing so it's definitely not dead, and occasionally it will turn on but turn off instantly, I have tried the factory reset thing so if anyone is having the same problem or has any solutions please reply
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
RayyanS04  the symptoms you describe are pretty consistent with a bad battery. Remember that even a bad battery will tell you it is charging but will not hold a charge. Replace the battery and re-evaluate.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hi0bui9bvivbibuboihiohi097awrestdyfugihj
IDK why I’m on this site:::::::: This site helps with nothing better just to go get it fixed than waste your time on this site.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
RayyanS04 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 326
