주요 콘텐츠로 건너뛰기
Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
2704 질문 전체 보기
How to open up the Anker A7908 Bluetooth speaker?
My Anker A7908 is having some issues and I wanna take a look inside, but I'm not entirely sure where to start with taking this thing apart. I don't want to just start prying an pulling in random places. Does anybody have any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Manufacturers love to hide screws under rubber feet. Try prying that rubber base off.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
You were right. Thank you very much!
Hi! I got the screws out but I'm not seeing a good place to be able to pry the bottom off. What did you do once you got the screws out?
댓글 달기
@printedwaffles, after that there is only one tiny part that may still stick a bit.
Visible on the right of the picture (marked with silver marker).
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you, I'll give it a try soon. Did you use a plastic/rubber/metal pry piece to get that to pop out?
I'm pulling it apart because the battery is toast. Do you happen to know the right type of replacement battery for this thing?
Thank you! Very much appreciated!
댓글 달기
Important in my effort to get the bottom off - there are FIVE screws in the bottom!
I was trying to pry off the bottom after having removed screws on four sides and it wouldn't budge at all. Only by luck did I realize a fifth screw was hidden under the glue strip.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Now that I have it apart I was able to check the battery. It's at roughly 4 Volt, so fully charged, but it still won't turn on. Any tips? The only light I get is the red light when connected to a charger. the on-off button or the others aren't doing anything.
댓글 달기
귀하의 답변을 추가하세요
Lars Lensink 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 48
전체 시간: 1,507
