주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
How to fit that plastic bit inside the LCD assembly?
Just bought a screen but it doesn’t come with the transparent plastic bit that fits underneath the notch.
There is a hook in that plastic part (circled in blue).
Also, the LCD assembly that I received has some kind of little plastic bit inside where the earpiece fits (circled in red). It prevents the earpiece (circled in green) from fitting into its normal place.
Is there a way I can fit this? Am I supposed to unglue the metal frame that is all around the screen assembly, for it to fit?
Will anything bad happen if I just cut off that little hook?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
As long as the plastic doesn’t warp too much and prevent the FaceID sensors from working, it should be fine to get rid of that little part. No need to glue the plastic down but simply put the sensors, camera, and speaker on top of it and screw it all down. Might be a little tricky but take your time and don’t screw anything in too much if there’s any resistance and the sensors aren’t all flush with the screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alex222 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 85
